Redundancy (Desaster Recovry)
Aug 20th, 2007
Wanting to set up some redundancy (I guess that is what you would call it) for my network. Basiclly co locate my servers... So if we happen to get hit ny a missle are something the network will redirect to my secondary location...
Location A (Main Location)
- Cisco 1711 Router
- Pix 506E Firewall
- 19 Servers
Location B
- Pix 506E Firewall
- Thin Clients
(Moving Domain Controller Backup there tomorrow)
Danilo Dy Mon, 08/20/2007 - 07:17
  • Blue, 1500 points or more
I think you miss the question :)
However, I have setup multiple redundant location separated geographically. I setup IPSEC VPN between firewalls to make the AD sync its DB and also use MS Sync Toy to copy other apps data from PR Server to DR Server, script for X server. So when the PR is hit by a missile, hopefully I wasn't there, I can just make the SLAVE DNS in DR as MASTER and change the record to point to DR and voila it's up. Have to perform DR activation periodically though (i.e. once a year) to make sure all personnel is in-sync and the process still works specially the DB that supposed to be sync. For server with big DB, need an off-site backup to send to remote site or better yet (if you can afford) get a higher bandwidth pipe between sites to sync DB.
Dandy
