Quires on Cisco FAX server
Aug 20th, 2007
We are planning to use Cisco 7825-H2 for Cisco FAX server. Our IPT network is designed cluster based topology with 3 servers (1P and 2S) with Cisco unity servers for UM and VM services.
I have few queries on FAX server
1. Cisco FAX serer can install on Cisco Unity?
2. Cisco FAX server have capability to send the documents to users which are located on remote network. (WAN topology)
3. Cisc 7825-H2 having any limitations for communicating with Industry rating FAX machines.
4. Cisco FAX server can communicate with Nortel PBX systems.
I requested you please clarify my quires on Cisco FAX server.
Ginger Dillon Tue, 08/21/2007 - 10:23
Hi -
Here is a good link that will answer some of your questions - http://www.cisco.com/en/US/customer/products/ps6178/products_data_sheet0900aecd802638f9.html
You will note the fax server cannot be colocated with Unity on same server. The document shows a sample deployment scenario. The server you are considering does not support fax voice boards, i.e. it is boardless fax over IP. Here is another link for the full documentation - http://www.cisco.com/en/US/customer/products/ps6178/tsd_products_support_series_home.html
Regards, Ginger
rangakishore Tue, 08/21/2007 - 20:58
Thanks Ginger
I goen through the document, I have query on Cisco MCS 7825 server having any limitations?
Thanking you,
Ranga Kishroe
