Error in Cisco Network Assistant 5.2
Answered Question
Aug 20th, 2007
telnet_launch_helper.bat pops up everytime I try to right click and telnet. Any ideas?
John
Correct Answer by aborole about 9 years 7 months ago
It is directly in the userhome folder (no subfolder). Log does not show any error messages - mayeb you could try again and make it fail before getting the log to see if it makes any difference.
Overall Rating: 5 (1 ratings)
aborole Mon, 08/20/2007 - 06:43
  • Cisco Employee,
does it give any error or is the telnet window launched as expected ?
kinderknechtj Mon, 08/20/2007 - 06:57
No it does not just a windows box shows up saying it cannot find the file the only option is to click ok. No telnet window opens up.
aborole Mon, 08/20/2007 - 07:01
  • Cisco Employee,
What OS is the problem seen on ? It is possible that application is not able to create the required batch file in the user home directory.
aborole Mon, 08/20/2007 - 07:33
  • Cisco Employee,
In the user home dir for eg: C:\Documents and Settings\ - make sure application has read write permission to that folder.
If the operation still fails, it could be some other error - you could post the text from java console which can be opened by clicking F2 when the application window has focus.
Correct Answer
aborole Mon, 08/20/2007 - 07:55
  • Cisco Employee,
aborole Mon, 08/20/2007 - 11:09
  • Cisco Employee,
Is it a common scenario that users do not have write permission to the user home directory ?
