Extension Mobility. EMProvider
Aug 20th, 2007
Hello?.
Im trying to make a connection between my application (Java) and the Extension Mobility. I already configure all the EM application in the callManager, and it works. I can login and logout through the phone.
Now, I want my application do some tasks like ?knowing if a user is login or know the device name of the phone is login in?.
Here is a piece of my code:
EMProvider emp = new EMProvider(callManager, callManagerUserId, callManagerPassword, extMobUserId, extMobPassword);
My problem is that I don?t know what I should introduce in ExtensionMobility UserID and Password. I did the entire EM configuration and I don?t recall any UserID or password in the configuration process.
So? what those variables supposed to mean? Where can I see it or where I can reset them?
Thanks for your help and time.
stephan.steiner Tue, 08/28/2007 - 00:38
  • Silver, 250 points or more
It's the login/password of a user having extension mobility proxy rights.
You could also use any em enabled user's login and password but that limits you to log in/out that particular user.
