Memory Usage
Aug 20th, 2007
Hi all,
I am running PIX 515e in a failover environment. The PIX has 128MB memory and currently it is using 113MB of the momory. Is that normal? How can I check where it is using this much memory? What is the maximum it can go without crashing?
Thanks.
rajbhatt Tue, 08/21/2007 - 00:46
Hi Shoaib,
Please check the following :
Which code r u running?
Your syslogging is it turned on level debugging?
sh logg ( turn off bufrred looging if that is on )
sh xl count
sh conn (if there an attack ?)
sh conn count
Sh performance
sh mem detail
sh mem blocks
sh cpu usage
sh proc (to see if any particular process is consuming the memory )
These statistics should give u some idea if there is a problem
Raj
shoaib.usmani Tue, 08/21/2007 - 01:14
Hi Raj,
Thanks for your help.
I am running version 7.22.
I don't see anything wrong with the output of the commands you sent. Most of the setting are set to default e.g log buffer etc.
Regards.
