Air-ap1121g-a-k9 will not recieve c1100-k9w7-tar.default from tftp
Aug 20th, 2007
I have 3 of these units that have no image and need an image loaded but they will request the file from the tftp server but wont recieve it. Any Clues to what could be going on?
Thanks ahead of time
Rob Huffman Mon, 08/20/2007 - 08:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Gary,
Sounds like a TFTP problem for sure :(
Have a look at the details in the following threads that all have to do with TFTP. There are some great hints for troubleshooting TFTP problems from some of my favourite NetPros like ScottMac,Stephen from Cisco and Jack Young. The likely culprit may be that you need to uncheck "hide extensions for known file types" on your TFTP server;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=WLAN%20Radio%20Standards&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddc042b/8#selected_message
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddc03c4/2#selected_message
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddbf271
Maybe try this (highly recommended version)
Solar Winds tftp
http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
The problem could be that the Laptop (used for TFTP) Operating System is hiding the known file type. From Internet Explorer, go into Tools > Folder Options > View, scroll down until you find the parameter Hide extensions for known file types, and uncheck the box. This should eliminate the issue.
Hope this helps! Good Luck!
Rob
garylash8016 Mon, 08/20/2007 - 08:57
Rob, Thanks for the response.
I tried your suggestion. But that has not solved my problem. I have other 1121's that the image recovery proceedure works with the Tftp server i have(Klever's Pumpkin TFTP). these units have come back from a customer and they used a differant tftp and got the same results. the tftp server is getting a request from the 1121's for the file c1100-k9w7-tar.default.tar, but the transfer never starts. Its as if the AP is either not recieving the ACK or not sending an ACK for the transfer to start.
Gary
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
