CME and discard 9
Aug 20th, 2007
I've very new to CME/CUE and need some advice on part of my dial plan. I'm trying to implement dial "9" to dial out, but I find that my dial-peer is passing everything to the telco including the "9". Is there a command or a method that will allow me to discard it or to discard a pre-dot like in regular CallManager?
rob.huffman Mon, 08/20/2007 - 09:19
Hi Shikamaru,
Here is what Cisco recommends in the CME SRND Guide;
!11-digit long-distance PSTN dialing with an access code of 9
dial-peer voice 1 pots
preference 1
destination-pattern 91..........
port 2/0:23
forward-digits 11
!7-digit local PSTN dialing with an access code of 9
dial-peer voice 4 pots
destination-pattern 9[2-9]......
port 2/0:23
forward-digits 7
From this good design doc;
Cisco Unified CallManager Express Solution Reference Network Design Guide
Cisco Unified CallManager Express Dial Plan
Hope this helps!
shikamarunara Mon, 08/20/2007 - 09:28
Thanks for the reality check, Rob. Yeah, I stumbled into the world of "forward-digits" when I was doing some dial peer dubugging, good to see my mind was on the right track. I got the international dialing to work, now trying to figure out how the local dialing will go.
