MLA password configuration are there any settings?
Aug 20th, 2007
Once you create a user in an MLA configuration. Is there a way to manage passwords or is the password the same as the ccmadministrator password?
mchandak Mon, 08/20/2007 - 08:57
  • Gold, 750 points or more
Yes, the default username for MLA is CCMAdministrator and the default password for the same should be "ciscocisco". Incase this does not work, you can try using CCMPwdChanger (Start|Run|CCMPwdChanger) and reset the password for this account.
Hope this helps
