Monitoring ME 3400 QoS.
Aug 20th, 2007
2 questions:
We have a ME 3400 con qos configured, we'd like to monitor the bw per class, we have two ways, one using the "show policy-map interface output/input" however the output is not showing the bps rate:
Switch#show policy-map interface output
FastEthernet0/1
Service-policy output: OUT
Class-map: VO (match-any)
0 packets
Match: qos-group 1
Priority
police cir 2000000 bc 62500
conform-action transmit
exceed-action drop
conform: 0 (packets) exceed: 0 (packets)
Output Queue:
Max queue-limit default threshold: 16
Tail Packets Drop: 0
Class-map: DCO (match-any)
1414 packets
Match: qos-group 2
Traffic Shaping
Average Rate Traffic Shaping
CIR 5000000 (bps)
Output Queue:
Max queue-limit default threshold: 48
Class-map: class-default (match-any)
3830 packets
Match: any
Output Queue:
Bandwidth 3000 (kbps)
Output Queue:
1. Is there a way to see the bps rate per class?
2. Using SNMP did not work also. Any help???
Thanks and regards
swaroop.potdar Thu, 08/23/2007 - 10:13
12.2(35)SE, 12.2(25)SEG1 & SEG , 12.2(25)EX1 & EX These release for the ME3400 support Class-Based-QOS-MIB
HTH-Cheers,
Swaroop
swaroop.potdar Fri, 08/24/2007 - 06:03
Mario, I agree to what you have mentioned,but I believe the above list should be reliable, do give it a try and check.
HTH-Cheers,
Swaroop
swaroop.potdar Fri, 08/24/2007 - 06:34
Can you try the CLI command as follows,
show policy-map interface [ specify interface id here or leave it] output/input.
for Eg:
show policy-map interface fa0/1 output.
HTH-Cheers,
Swaroop
