08-20-2007 10:19 AM - edited 03-11-2019 03:59 AM
Hi folks.
I've searched through the online docs, but can't find a definitive answer to the following question:
Can I upgrade the memory on a 5510 or 5520? I'm specifically referring to RAM, not to the flash/compact flash.
One of my ASA's is only at 9% CPU, but at 50% memory. I don't want/need to upgrade to the 5540, because really only RAM is the current rate limiting factor.
08-20-2007 11:19 AM
If you check in the ASA datasheet Cisco doesn't list any memory other than flash memory.
08-20-2007 11:33 AM
the DRAM is not upgradeable in the 5510 , i'm not sure about the others. This way when a newer OS comes out down the road that requires even more RAM, you'll have to buy an entirely new device - unlike w/ the PIX ;)
atleast, imho....
