CallManager 3.3 - Reports - DNs & Voice Mail Profiles
Aug 20th, 2007
Is there a way to generate a report that shows a list of Directory Numbers and what Voice Mail Profiles they are using? Thanks in advance.
pklos Mon, 08/20/2007 - 10:27
  • Silver, 250 points or more
yes, you can do SQL Query. you should check table NumPlan
simple sample:
select n.DnOrPattern, v.Name as VoiceMail from numplan n, voicemessagingprofile v where n.fkVoiceMessagingProfile = v.pkid
