howto simulate a pri on 2600
Aug 20th, 2007
I have a 2651XM with a 1DSU-T1 and a WIC-2MFT-t1 and need to use either of these WIC's to simulate a PRI. I assume this is possible, but have not been able to find any info on it. The phone guys have asked if there was a way to get them a PRI to test remote office PBX's before they ship.
arcaidy76 Mon, 08/20/2007 - 11:16
  • Bronze, 100 points or more
Are you using the with Call Manager or another IP PBX?
pacameron Thu, 09/06/2007 - 06:09
  • Silver, 250 points or more
You can simulate a voice PRI on a 2600 as long as you have DSP resources. If you want to make voice calls through it, the easiest way is to use something like a NM-2V card with VIC-2FXS , the AIM-VOICE-30 DSP card and a VWIC-1MFT-T1 card.
The following config would work -
isdn switch-type primary-ni
network-clock-participate wic 0
network-clock-select 1 t1 0/0
controller t1 0/0
pri-group timeslots 1-24
interface serial 0/0:23
isdn incoming-voice voice
isdn protocol-emulate network
dial-peer voice 1 pots
incoming called-number .
port 0/0:23
direct-inward-dial
dial-peer voice 2 pots
description - calls to PRI
destination-pattern 1...
port 0/0:23
prefix 1
dial-peer voice 3 pots
description - calls to FXS ports
destination-pattern 2...
port 1/0/0
we use these configs all the time in the lab as PBX simulators . You need a T1 cross over cable to bring up the interface -
1 ---- 4
2 ---- 5
4 ---- 1
5 ---- 2
