Display pre-defined caller info
Aug 20th, 2007
I am trying to set up several hunt groups for inbound 800 numbers. I want each hunt group to display on the IP phones screen a specific name and phone number for the person receiving the call knows which number was called.
For example, a caller dials 1-800-555-1234. It hit the hunt group and the 5 phones in the group ring. The phone then displays on the screen the following:
Test 800 Number
18005551234
How do I set this up?
Scott
bwilmoth Fri, 08/24/2007 - 13:23
  • Silver, 250 points or more
You can try with transfomration mask
johutchins Sat, 08/25/2007 - 17:19
I would try creating a CTI RP to match the 800# and set the CFA to the Hunt Pilot number. I beleive CM sends the name of station that is forwarding a call from...
