anandramapathy Wed, 08/22/2007 - 01:22
  • Bronze, 100 points or more
Wasted 4 days on this last month.
If you have ASDM 5.2 & IPS 6.x then you can directly reset the password from the ASDM ( Tools, IPS password reset )
Can you tell us what is the version of the IPS ?
If it is greater than 6, then the hw-module password reset will work, if it is 5.X you have to reimage the AIP SSM as above link
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_password_recovery09186a0080094e83.shtml#insta
