Jon Marshall Mon, 08/20/2007 - 23:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
From the Pix 501 data sheet.
Performance Summary
Cleartext throughput: Up to 60 Mbps
Concurrent connections: 7,500
56-bit DES IPsec VPN throughput: Up to 6 Mbps
168-bit 3DES IPsec VPN throughput: Up to 3 Mbps
128-bit AES IPsec VPN throughput: Up to 4.5 Mbps
Simultaneous VPN peers: 10*
* Maximum number of simultaneous site-to-site or remote access IKE Security Association (SAs) supported
So the answer is 10.
Jon
