Catalyst 6506 Fan Tray
Aug 20th, 2007
I'm having a Catalyst 6506 with a Sup1 which I'm looking to replace by a Sup32, but I'm not able to check if the Fan tray is what I need for supporting the Sup32. Is there someone which knows how to check if we have a fan tray inside, and is there different fan trays, or there is one or there is none?
if I do sh modules I get:
sh modu
Mod Ports Card Type Model Serial No.
2 2 Cat 6k sup 1 Enhanced QoS (Active) WS-X6K-SUP1A-2GE SAL0542DDJ7
3 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC SAL0543DJBD
4 24 24 port 100FX Multi mode WS-X6324-100FX-MM SAD055005KG
5 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0547EH4V
Mod MAC addresses Hw Fw Sw Status
2 0006.d659.de28 to 0006.d659.de29 7.1 5.4(2) 7.5(0.6)HUB2 Ok
3 0007.4f6d.45b0 to 0007.4f6d.45bf 1.0 5.4(2) 7.5(0.6)HUB2 Ok
4 0002.fcbd.b288 to 0002.fcbd.b29f 3.0 5.4(2) 7.5(0.6)HUB2 Ok
5 0005.7409.7928 to 0005.7409.7957 5.0 5.4(2) 7.5(0.6)HUB2 Ok
Mod Sub-Module Model Serial Hw Status
2 Policy Feature Card WS-F6K-PFC SAL0542DB38 1.1 Ok
2 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0541D4YB 1.2 Ok
5 Inline Power Module WS-F6K-PWR 1.0 Ok
if I do sh power, I also don't find references to the fan tray:
system power redundancy mode = redundant
system power total = 1153.32 Watts (27.46 Amps @ 42V)
system power used = 532.98 Watts (12.69 Amps @ 42V)
system power available = 620.34 Watts (14.77 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-1300W 1153.32 27.46 OK OK on
2 WS-CAC-1300W 1153.32 27.46 OK OK on
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 - - 121.80 2.90 - -
2 WS-X6K-SUP1A-2GE 121.80 2.90 121.80 2.90 on on
3 WS-X6416-GBIC 118.02 2.81 118.02 2.81 on on
4 WS-X6324-100FX-MM 63.84 1.52 63.84 1.52 on on
5 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 on on
Inline Inline
5 WS-X6348-RJ-45 - - 7.14 0.17
Overall Rating: 5 (1 ratings)
Edison Ortiz Mon, 08/20/2007 - 15:00
  • Hall of Fame,
    Founding Member
Try the command 'show environment status'
jorge.s Mon, 08/20/2007 - 15:32
yes, fan tray is in there.
but do we have different fantrays, or is just one type, having it is ok for Sup32, or not having it is not ok?
sundar.palaniappan Mon, 08/20/2007 - 16:01
  • Green, 3000 points or more
Quoting from the link below.
Supervisor Engine 32 requires the high-speed fan tray when operating in the Cisco Catalyst 6500 chassis. As such, a minimum of 2500W AC (in either 110V or 220V mode) or DC power supply is required for operation in a 6-, 9-, and 13-slot chassis.
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd801ff3ee.html
Sundar
