Catalyst 6513 Newbie
We just received a 6513 with 2 Sup modules and 5 Gigabit switch modules. I wanna get to the web management of the 6513. I assigned an IP address to the default interface using the IOS commands but I still can not get to the web interface. I have looked all over the web on how to do this, but have not found anything.
Does anyone have documentation or a config example for how to setup the switch just enough to get to the web interface.
spremkumar Mon, 08/20/2007 - 19:13
  • Red, 2250 points or more
Hi Matt
I would prefer configuring using CLI instead of going for Web Interface.
People tend to make use of web interface if its a simple lower level equipments or entry level equipments.
you can make use of the following link to configure the features/modules which you require to do so .
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_technical_reference_list.html
regds
