table relationships-
Answered Question
Aug 20th, 2007
I ran the cwexport command to dump a view from the RME 3.5 DB to an xml file.
I then imported the data into Access. There were a number of inventory tables imported. I saw where the Cisco_Card, Cisco_Chassis and Network_Element tables (I think the table names are correct) had valuable Card and Chassis information but was unable to run a query against the 3 tables because they have no relationship between them.
Is there something I'm missing or can I get my hands on a sheet showing how the tables are related to each other?
Correct Answer by Joe Clarke about 9 years 5 months ago
You can get the XML schema to which the DEE data validates from the online help at http://server/help/DEEV2/inventory_schema.html .
Overall Rating: 5 (1 ratings)
