Transparent Firewall
Aug 20th, 2007
I have read the following definition a couple times:
Transparent mode, the FWSM acts like a "bump in the wire," or a "stealth firewall," and is not a router hop.
What I understand with the previous sentence is that: The FWSM connects the same network on its inside and outside interfaces, but each interface must be on a different VLAN.
However, are both vlans going to share same subnet???
rochopra Mon, 08/20/2007 - 16:06
  • Cisco Employee,
Transparent firewall will bridge between vlan and not route, so if you are using different subnets you will need layer 3 routing device to route packets between subnets.
~Rohit
Jon Marshall Mon, 08/20/2007 - 22:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
In answer to your question yes you have 2 vlans but only one IP subnet. This setup is also used on other devices such as load balancers.
The reason you need to do this is to avoid a spanning-tree loop. Assuming you are running PVST+ then having 2 vlans but only one subnet allows you to bridge the subnet with the FWSM.
Jon
