MLPPP with WIC-1DSU-56K4
Aug 20th, 2007
I have a remote customer location that has limited access provided by the LEC. Only DDS circuits are available. Using MLPPP, Can a Cisco router bundle together multiple DDS/DSO either terminated on a channelized DS1 card or individual WIC-1DSU-56K4 ports.
royalblues Tue, 08/21/2007 - 01:08
Yes you should be able to multilink individual WIC-1DSU-56K4 ports.
Just configure each link and associate them with the multilink group
On the other side, you can go for a version2 card which supports multiple channel groups and map each of them to 56K4 ports on the other side in multilink
