CM 4.1(3)sr5b on Win2003?
Aug 20th, 2007
Can anyone show me some proof that CM ver 4.1(3)sr5b will work on Windows 2003?
We are planning to upgrade this week to Win 2003 and looking if this upgrade will give us some issue.
tia
Robert
mchandak Tue, 08/21/2007 - 05:41
Well .. this would not work. OS 2003.1.1 and above is only supported with CM 4.3 onwards only. Therefore you cannot install CM 4.1(3) with Windows 2003
redrobish Tue, 04/01/2008 - 22:51
Thanks for the reply.
Now we are ready for the upgrade.
Can anyone give me some good procedure or step by step on how to install CCM 4.3(2) on a new win2003 server.
tnx
Rob Huffman Wed, 04/02/2008 - 05:50
Hi Robert,
These are probably two of the better places to start the Upgrade path :) Pretty good docs;
Cisco Unified CallManager Documentation Guide for Release 4.3(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/docguide/4_3/dg431.html
Upgrading Cisco Unified CallManager, Release 4.3(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/4_3_1/upg431.html
Hope this helps and best of luck!
Rob
