LMS size
Aug 20th, 2007
Hi ,
I have installed LMS 2.6 on windows. According to the document it says the minimum size of the disk needed is 20 GB or more ,I have installed it on 60 GB server.But my disk is getting utilised very fast ,From last 10 day i have already crossed 28 GB's.Please let me now what are the things i need to consider so that the server runs smoothly.
Let me know if i need to trim some file or if i have to set some jobs and how.
Joe Clarke Mon, 08/20/2007 - 22:02
What is occupying the disk space? Figuring out where the disk space is going well help determine the exact steps that need to be taken to remedy the situation.
yusufujjainwala Tue, 08/21/2007 - 02:23
See if your syslog.txt file is increasing , if so pls disable unwanted trap logging. Keep only the Critical traps if required.
