Edison Ortiz Tue, 08/21/2007 - 18:34
If you want to know how much traffic the link is using at that moment, you can type show interface serial x/x and see the input/output rate stats.
By default the interval capture is 5 minutes, you can change this behavior to 30 seconds by entering the following command under the interface:
load-interval 30
