% Authorization failed.
Answered Question
Aug 21st, 2007
Can you help me to Understand that when I am adding aaa template to a switch which I am connected with telnet give me the error % Authorization failed
and accounting part is not unable to be added. Also is unable to connect to this switch again. Even username admin is added , The template was:
username admin password admin
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization config-commands
aaa accounting system default start-stop group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
tacacs-server host 172.16.101.247 key X
Correct Answer by rochopra about 9 years 11 months ago
change template to :
aaa new-model
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
Then try to add, this is happening cause you are enabling authorization but are logged in with unprivileged account.
~Rohit
Overall Rating: 5 (1 ratings)
Correct Answer
rochopra Tue, 08/21/2007 - 01:35
  • Cisco Employee,
aaa new-model
~Rohit
