How to check DSCP field without phuysical access
Answered Question
Aug 21st, 2007
Hi all,
We need check if the packets leaving our 3750 in a specific port are actually marked with EF. But we can't use a sniffer. Any idea? I've been trying some "sh mls qos" but the outputs don't show anything...
thanks in advance,
Correct Answer by royalblues about 9 years 6 months ago
Can you try
sh mls qos interface statistics or
sh mls qos interface statictics.
These commands should tell you whether DSCP is being set correctly
Narayan
please rate all posts
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Tue, 08/21/2007 - 02:26
Can you try
Narayan
