I have a question about GSS
Answered Question
Aug 21st, 2007
I must install two gss on active/standby mode
First, I enable one GSS to primary gssm, like below
#gss enable gssm-primary
and then I enable the other gss to secondary gssm like below
#gss enable gssm-standby (gssm-primary'ip)
In the configuration, Is it a correct?
and How can I cabling each other?
Must it be in same sagment to establish active/standby mode?
Or, don't care when gss can communication
each other?
in the dns server, How can I setup ip address?
dns must look at two ip(active gss, standby gss)? or only active gss?
thank for your reply.
Correct Answer by rajesh.perumalla about 9 years 2 months ago
Hi syejeon,
GSS's can be in different networks and there should be communication between the GSS's.
In the interface configuration - you need to define "gss-communications".
Check the link for the GSS-DNS configuration
Overall Rating: 5 (1 ratings)
