08-21-2007 04:21 AM - edited 03-14-2019 11:09 PM
When trying to add a MOH file, the find and list comes up with this.
We had a MP3 file converted to a WAV file then this happened when we tried to upload it. The new file shows under MOH audio sources but saids the file is not there and lists no properties for
the audio source.
Unmapped exception. The entity name must immediately follow the '&' in
the entity reference.
0 records found, 133 minutes available.
Solved! Go to Solution.
08-21-2007 04:44 AM
Hi Erick,
Have a look at this good post from Mahesh @ Cisco Systems that details the 5.1.1 Bug that you are hitting along with the ES notes for the required fix;
Hope this helps!
Rob
08-21-2007 04:44 AM
Hi Erick,
Hope this helps!
Rob
