Warning message
Hybrid 6500 with HSRP and Multicast
Aug 21st, 2007
I am running into an issue with multicast and HSRP on a hybrid 6500. The 6500 has redundancy implemented and there is a primary and alternate ip address required for each interface. Unicast routing is using a both the primary and alternate ip address to get to different destinations. In some cases if there are two different ip addresses on the 6500 each will use a different IP as the next hop. I believe because of this I am getting RPF failures. I tried adding adding static mroutes but this does not seem to help. I was able to associate with the RP via autorp but when i do a ping test using the ip igmp join-group that's when i am seeing this issue.
any help would be greatly appreciated.
nambi_gct Tue, 08/21/2007 - 05:44
  • Bronze, 100 points or more
HTH.
Q. Can I use Hot Standby Router Protocol for Multicast?
A. Hot Standby Router Protocol (HSRP) is designed for host in last hop networks, in order to have a failover for Unicast routing. It is not generally recommended to use HSRP for IP multicast routing.
For additional information, please visit:
http://www.cisco.com/warp/public/619/hsrpmcast.html
Edison Ortiz Tue, 08/21/2007 - 18:10
  • Hall of Fame,
    Founding Member
Can we see that portion of the config along with the output from
show ip mroute
show ip mroute count
show ip pim rp mapping
