Lan-to-Lan in VPN Cluster
Aug 21st, 2007
hi,
I have configured a VPN Cluster on two 3030 Concentrators, my VPN Clients both IPSec and PPTP are successfully connecting to the concentrator but the LAN-to-LAN.
my question is do i have to connect to the cluster ip or the physical concentrator ip of one of the cluster concentrator.
Overall Rating: 3 (1 ratings)
b.hsu Mon, 08/27/2007 - 10:53
  • Silver, 250 points or more
Load balancing is effective only on remote sessions initiated with the Cisco VPN Client (Release 3.0 and later) or the Cisco VPN 3002 Hardware Client (Release 3.5). All other clients, including LAN-to-LAN connections, can connect to a VPN Concentrator on which load balancing is enabled, but they cannot participate in load balancing.
thinkingodd Mon, 08/27/2007 - 19:57
thanks for the reply dear...
dear i have switched to VRRP from loadbalancing...as my client was having more lan2lan tunnels than remote sessions.
thx again...
