Certificates for IAS
Aug 21st, 2007
Do I have to install the certificate from the CA on the WLC 4400? I exported a cert from our CA(someone else set that thing up and I am not totally sure it is right) and installed on a laptop and tried to get to the WLAN that I setup with 802.1x and I get no where. I do have the IAS server setup as a Radius on the WLC. All I get is "Aug 21 08:18:35.728 1x_auth_pae.c:2471 DOT1X-1-MAX_EAP_IE_RETRIES_REACHED: Reached Max EAP-Identity Request retries (21) for STA00:1b:77:25:44:cf" in the logs and nothing on the IAS server or the CA server. I am not getting a whole lot go on here.
Anyone got any idea of what is wrong here?
fynskisb16 Tue, 08/21/2007 - 08:18
How do you have your IAS server setup? Are you running on a 2003 Domain? I'm running 6 IAS server that are DC's that talk with 8 4400 series controllers. I've had issues with IAS but I think we have it all worked out. I currently working on a doc that I can send you if you would like.
fynskisb16 Thu, 08/23/2007 - 10:34
I'm working on adding the WLC to the document. It will show all the steps for 802.1x PEAP with IAS and windows clients.
