How do I remove a single ACL line in a 2811 router?
Aug 21st, 2007
I need to remove one line of code in a Cisco 2811 router, without removing the entire ACL. I'm used to making these changes in firewalls, but have figured out it's a little different in the router. Can someone provide me with some instruction? I heard I need to go into a sub-interface of the acl, but how do I do that?
Also, will making this change affect any traffic routing through this router?
Thanks for the help, I'm going to need to make this change within the next hour or so.
1 vote
Overall Rating: 5 (7 ratings)
kevin.shi Tue, 08/21/2007 - 08:15
If it is a extended CAL(100-199), you can go to extended mode to delete/add items without affecting live traffic.
for example:
ip access-list extended 120
no .....
ttrevino1 Tue, 08/21/2007 - 08:30
It is, 101. So if I use that command,
"ip access-list extended 101", that will put me into the sub-interface, allowing me to remove individual lines of code?
kevin.shi Tue, 08/21/2007 - 08:46
ip access-list extended 101 then press 'enter'
you will get into 'sub-interface' of ACL
anandramapathy Wed, 08/22/2007 - 00:51
The process is as follows
show access-list (NAME )
It will show you the access list with the line number
10 Line 1
20 Line 2
30 Line 3
40 Line 4
Suppose you want to remove Line 3,
conf t
ip accesss-list extended (name )
>no 30
That should remove your Line.
HTH Pls rate if it helps
