Converting to HA
Aug 21st, 2007
Anyone know how to convert a single server IPCC Express (4.05) to a 4 server cluster? With this model, 2 servers run engine and 2 run database/record/monitor, but can you restore the database and save the applications, scripts, and prompts? Would you have to rebuild the original server to only run the components needed? In what order would you (re)install, and when would SQL be installed? I know how to do this in a new install, but converting has me scratching my head!
Thanks!
