Upgrading Cisco Unity
Answered Question
Aug 21st, 2007
I have a Unity Server running unified messaging and at version 4.0(5). I'm looking at doing an upgrade to version 4.1(1). Are there any compatibility issues with running Callmanager 4.1(3); also, will the hardware need to be MCS, or are non-MCS installations supported with this software?
Correct Answer by Ginger Dillon about 9 years 10 months ago
Hi -
The Unity platforms list details the supported MCS and non-MCS server hardware for running Unity. Is there a reason you don't want to go to Unity 4.2 or 5.0? Both support CallManager 4.1(3), which is our current version.
http://www.cisco.com/application/pdf/en/us/guest/products/ps2237/c1650/cdccont_0900aecd802132ef.pdf
Ginger
Overall Rating: 4.7 (3 ratings)
Correct Answer
Ginger Dillon Tue, 08/21/2007 - 10:54
  • Blue, 1500 points or more
Hi -
Ginger
lyle.langston Tue, 08/21/2007 - 11:18
From what I had read, I wasn't sure that 4.2 would be supported with CCM 4.1(3). Now this changes things for planning. Thanks!
ranpierce Tue, 08/21/2007 - 11:31
  • Silver, 250 points or more
We run CCM 4.1(3) and Unity 4.2(1), upgraded from 4.0(5). We are really concidering upgrading to 5.x. You might also. There are some nice features and CCM 4.1(3) is still supported.
The only thing is there might be licensing issues to consider.
CCO account needed:
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/unity/5x/release/notes/501curelnotes.html
rlp
Ginger Dillon Tue, 08/21/2007 - 11:51
Hi -
Randy is correct - 5.X requires a license upgrade via Product Upgrade Tool. Mine took about 10 days, I think, to order and ship.
Ginger
Rob Huffman Fri, 09/21/2007 - 17:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Taylor,
You are correct 4.0 to 4.1 or 4.2 does not have any licensing requirements unless you are changing servers :) Here are the pertinent docs;
Upgrading Cisco Unity 4.x Software to the Shipping Version
http://cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_010.html
Release Notes for Cisco Unity Release 4.2(1)
http://cisco.com/en/US/docs/voice_ip_comm/unity/42/release/notes/cu421rn.html#wp39989
Hope this helps!
Rob
Rob Huffman Fri, 09/21/2007 - 17:48
  • Hall of Fame,
    Founding Member
You are most welcome Taylor! Good luck with your upgrade :)
Take care,
Rob
