PIX515E OS 8.02 w/ASDM 6.02
Aug 21st, 2007
I am starting to notice some issues with this release. I have already noted that there appears to be issues with telnet/ssh/asdm access through an IPSec client to the management IP address of the PIX. I am also noticing that everytime the firewall is reloaded it looses the isakmp nat-traversal 20 command and I have to reapply it after the firewall has booted. I am 100% absolutely certain that I am writing to memory after each time I had to reinsert the command. Any one else out there experiencing issues with OS 8.02 on a PIX platform?
purohit_810 Tue, 08/21/2007 - 18:43
  • Silver, 250 points or more
Run SH VER command: how it boots that it will show you in 3-4 Line of output.
Sh file system : It will show you FLASH: " RW or RO "
What is in from of Flash checkout, it must be RW. if it is RO than change permission as RW.
Dharmesh Purohit
david.keil Tue, 08/21/2007 - 20:05
Thank you very much for your response. I ran the requested commands and everything appears to check out correctly. Please see the output below:
c-pix515e-fw# sh ver
Cisco PIX Security Appliance Software Version 8.0(2)
Device Manager Version 6.0(2)
Compiled on Fri 15-Jun-07 18:25 by builders
System image file is "flash:/image"
Config file at boot was "startup-config"
c-pix515e-fw up 10 hours 36 mins
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0 : address is 000b.4680.0000, irq 10
1: Ext: Ethernet1 : address is 000b.4680.0000, irq 11
2: Ext: Ethernet2 : address is 000f.a3e9.0000, irq 11
3: Ext: Ethernet3 : address is 000f.a3e9.0000, irq 10
4: Ext: Ethernet4 : address is 000f.a3e9.0000, irq 9
5: Ext: Ethernet5 : address is 000f.a3e9.0000, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
Serial Number:
Running Activation Key:
Configuration last modified by username at 12:52:04.368 PDT Tue Aug 21 2007
c-pix515e-fw# sh file system
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - network rw tftp:
- - opaque rw system:
- - network ro http:
- - network ro https:
- - network rw ftp:
* 16128000 1984512 disk rw flash:
