WLAN templates for an 877W
Aug 21st, 2007
Evening all, I'm trying to set up the above router with three seperate SSIDs, three different VLANs and three different rulebases. Can someone point me toward a template I can use or offer some advice?
steve.busby Thu, 08/23/2007 - 10:16
  • Silver, 250 points or more
Hate to point you outside of Cisco.com, but this template for two SSIDs on the 851W/871W looks like it could be a good way to start. I've not used it, nor tried it, but it may help.
http://blogs.zdnet.com/Ou/?p=313
Steve
jadehan Thu, 08/23/2007 - 12:10
I have a config that have been tested for the C871 router, which should be similar to the C877. I hope this helps. This is only for 2 SSIDs, but you can just keep adding to the set up for up to 10 SSIDs:
This is test sample for 2 vlans, vlan1 and vlan 10
both are BVI interfaces. 2 bridge-groups are being configured.
No cdp run globally, but enable cdp on FE ports for IP phones.
tester1#sh run
Building configuration...
hostname tester1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 172.30.220.1 172.30.220.10
ip dhcp excluded-address 172.30.220.129 172.30.220.138
ip dhcp pool wireless
import all
network 172.30.220.0 255.255.255.128
default-router 172.30.220.1
dns-server 4.2.2.1 4.2.2.2
domain-name vnus.com
ip dhcp pool wired-clients
import all
network 172.30.220.128 255.255.255.128
default-router 172.30.220.129
dns-server 4.2.2.1
bridge irb
interface FastEthernet0
switchport access vlan 10
spanning-tree portfast
cdp enable
interface FastEthernet1
switchport mode trunk
switchport voice vlan 10
cdp enable
interface FastEthernet2
cdp enable
interface FastEthernet3
cdp enable
interface FastEthernet4
description Internet
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 1 key 1 size 128bit xxx transmit-key
encryption vlan 1 mode wep mandatory
encryption vlan 10 key 1 size 128bit xxx transmit-key
encryption vlan 10 mode wep mandatory
ssid vnus-group
vlan 1
authentication open
guest-mode
ssid vnus-group2
vlan 10
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.10
encapsulation dot1Q 10
no cdp enable
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Vlan1
description user data network
no ip address
no ip redirects
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan10
no ip address
no ip redirects
bridge-group 10
interface BVI1
ip address 172.30.220.1 255.255.255.128
ip nat inside
interface BVI10
ip address 172.30.220.129 255.255.255.128
no ip redirects
ip nat inside
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map soho-vpn interface FastEthernet4 overload
access-list 23 permit 172.30.0.0 0.0.255.255
access-list 102 permit ip 172.30.0.0 0.0.255.255 any
route-map soho-vpn permit 10
match ip address 102
control-plane
bridge 1 route ip
bridge 10 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
