How do I clear the IP Counters on a 6509?
Answered Question
Aug 21st, 2007
I want to clear the counters shown when I use the command show ip counters. There is not a clear ip counters command. Clear counters does not clear these either.
Specifically, I have a LOT of "not a gateway" errors, I want to see if they are ancient or new. I also want to know what they heck that means.
Correct Answer by paulkeestra about 9 years 1 month ago
Overall Rating: 5 (1 ratings)
Richard Burts Tue, 08/21/2007 - 13:06
I wonder if you are confusing commands. I am not familiar with show ip counter. I am familiar with show ip traffic and in that display is a counter for not a gateway. And there is a clear ip traffic command. And it does clear those counters.
cybrsage Tue, 08/21/2007 - 13:21
Yeah, show ip traffic is what I meant.
How do I clear the info in that, so I have a zero point to start from?
I do not have a "clear ip traffic" command:
6509#clear ip traffic
% Invalid input detected at '^' marker.
(Note, the ^ appears under the "r" in traffic)
Anyone know what the "not a gateway" means?
I will repost this with the correct title...
cybrsage Wed, 08/22/2007 - 06:41
Well Poopies!!
System image file is "disk0:s72033-pk9s-mz.122-18.SXD5.bin"
