ACL ordering issue.
Aug 21st, 2007
Has anybody seen an issue such as below with ACL ordering?
I had the following ACL configured:
ip access-list extended QPM_WindowsSMB
permit tcp any eq 445 any
permit tcp any any eq 445
I noticed I wasn't getting any hits on the second line.
I changed the order of the first 2 elements and I started to get hits on both.
BTW, I upgraded the router IOS to 12.4(15)T1 on the weekend. Could this be a bug with this new software?
Cheers, SteveK.
royalblues Tue, 08/21/2007 - 13:49
None that i know of
It basically depends upon the traffic flow
As per the posted list, the first statement is trying to match the trafffic that has a source port of 445 and destination any
The second entry is doing the reverse.
Narayan
jwdoherty Tue, 08/21/2007 - 16:16
Another possibility is that any TCP traffic with a destination of port 445 always has a source port of 445. Assuming you didn't see this on your prior IOS, one would tend to suspect the new code.
You could turn on/off flow cache, and/or on/off compiled ACLs (if supported on your platform), and/or try a number access list and see if there's a change in behavior.
