I have two identical 2811 routers running the same code with the same hardware config. When I connect to one via https/http I get SDM, when I connect to the other I get SDM Express. I would like SDM instead of SDM Express. Any ideas? I am including the contents of flash that is identical on both routers. I compared files sizes also...
1 -rw- 19271408 Jun 14 2007 17:14:04 +00:00 c2800nm-advsecurityk9-mz.124-3g.bin
2 -rw- 1823 Jun 14 2007 17:22:36 +00:00 sdmconfig-2811.cfg
3 -rw- 6036480 Jun 14 2007 17:23:12 +00:00 sdm.tar
4 -rw- 861696 Jun 14 2007 17:23:30 +00:00 es.tar
5 -rw- 1164288 Jun 14 2007 17:23:46 +00:00 common.tar
6 -rw- 1038 Jun 14 2007 17:24:00 +00:00 home.shtml
7 -rw- 113152 Jun 14 2007 17:24:12 +00:00 home.tar
8 -rw- 527849 Jun 14 2007 17:24:30 +00:00 128MB.sdf
9 -rw- 1697952 Jun 14 2007 17:24:54 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
10 -rw- 416354 Jun 14 2007 17:25:18 +00:00 sslclient-win-1.1.3.173.pkg
Thanks in advance
