rate limit netflow export traffic on 7206
Aug 21st, 2007
Hello, Anyone has any idea on how to limit the traffic generated by 7206 (IOS 12.3(21)) netflow export ? By the way netflow is working for me, I am only trying to limit its traffic.
I tried to use policy-map policing but I could not pick up the netflow traffic no matter what I do, the ACL counter and the "sh policy map" does not show any matched traffic. I have even tried moving the neflow export source from loopback to an GigaEthernet interface but did not help.
Overall Rating: 4 (1 ratings)
ricwong Fri, 08/24/2007 - 08:55
Thanks very much ! sampling for every x number of lines is a form of rate limit. I will take a closer look at IOS support. I am using V5 so that should help.
Jan Nejman Thu, 08/23/2007 - 02:37
why do you want rate-limit netflow exports? Due to slow collector or do you have problem with line bottleneck? If you have a overloaded line I recommend connect collector directly on one interface. If you have a slow collector how many flows do you export to the collector [show ip flow-export]?
ricwong Fri, 08/24/2007 - 09:00
rate limit of netflow is required under adverse network condition, where netflow accounts for a sizable % of total traffic.
