Integrating CSM with ACS 4.0 problems
MIsatchenko
Has anyone had any luch with integrating CSM With ACS4.0?
I can authenticate a user but the problem is is it will only give level 1 privelige.
Is there any way to force the user to go to level 15?
I am using External database with Windows Authen.
Thanks in advance
rochopra
Following link can help you configure CSM with ACS.
http://www.cisco.com/en/US/partner/products/ps6498/products_user_guide_chapter09186a00806c2641.html#wp1302358
If using External Database make sure to do the Group mapping with right group, in order to get the right role/privilege.
~Rohit
Hi Rohit,
Thanks for your answer.
I have followed all of the procedures, but when I log in, I still only get level 1, where I actually want to log in as level 15...
Any idea?
Bring users/groups in at level 15
1. Go to user or group setup in ACS
2. Drop down to "TACACS+ Settings"
3. Place a check in "Shell (Exec)"
4. Place a check in "Privilege level" and enter "15" in the adjacent field
