QoS MIB in ME3400
Aug 21st, 2007
I am a little confused about the QoS MIB in ME3400.
THe ME3400 supports
CISCO-CLASS-BASED-QOS-MIB (using IP metro access software)
CISCO-PORT-QOS-MIB (using Metro access software)
WHat is the differce between the two ?
If i want to see the per class policing and per port per vlan statistics, which one do i need?
Eng Wee
David Stanford Tue, 08/21/2007 - 18:08
Where did you see that the CISCO-CLASS-BASED-QOS-MIB is supported by this device? I only see that the CISCO-PORT-QOS-MIB is supported.
e-chuah Tue, 08/21/2007 - 19:03
u can go to MIBs locator in CCO. Key in the platform as ME3400, IOS 12.2.25EX1 and IP metro access software. Then searched for CISCO-CLASS-BASED-QOS-MIB
David Stanford Tue, 08/21/2007 - 19:11
From what I see the CISCO-CLASS-BASED-QOS MIB is actually not supported by the ME3400 even though it appears here.
The CISCO-PORT-QOS-MIB is supported and have tested some objects to verify this.
e-chuah Tue, 08/21/2007 - 19:18
Hi Davistan,
So does the CISCO-PORT-QOS-MIB allows u to see per class policing statistics ?
Eng Wee
