To make a long story short I had upgraded my systems to a couple of the 4.0 images. Well nothing would connect from a notebook standpoint even though everything said it fine from the gui so I decided to downgrade to 3.2 since that was working. I'm using no security at this point I'll worry about that later. My problem is that out of 5 AP's that had the latest software now only 2 show up and I get these errors on the others.
Tue Aug 21 08:40:03 2007 AP Disassociated. Base Radio MAC:00:0b:85:55:fb:20
1 Tue Aug 21 08:40:03 2007 AP's Interface:1(802.11b) Operation State Down: Base Radio MAC:00:0b:85:55:fb:20 Cause=Max Retrasmission
2 Tue Aug 21 08:40:03 2007 AP's Interface:0(802.11a) Operation State Down: Base Radio MAC:00:0b:85:55:fb:20 Cause=Max Retrasmission
What is the Retrasmission? What do I need to do to get these AP's to hook in?
As you can see I'm a novice at this.
thanks
gary
