Mohamed Sobair Wed, 08/22/2007 - 03:47
One of the important issues that makes OSPF neighbor hangs on (Exstart state) is that a router is trying to make adjacency with a non DR/BDR on a segment. Offcourse those typically applied for NBMA & Broadcast OSPF Networks.
PLS try to influence the prioity at the interface level command to force the DR/BDR election.
NOTE: You may clear the OSPF process or reboot the router for the new election.
Mohamed Sobair
Mohamed Sobair Sun, 08/26/2007 - 04:43
EDIT>> Here is absolute case for the Exstart OSPF neighbor state:
If you are configuring OSPF Over NBMA and hardcoding the command (IP OSPF Network point-to-multipoint) on the Hub & Spokes, Please make sure you remove all L3-to-L2 mapping from all router interfaces.
The fact that OSPF treats all links as acollection of Point-to-Point links typically possible when changing the Network type of the interface by (IP OSPF Network point-to-multipoint), by doing so, its dynamically discovering neighbors & it creats by itself L3-to-L2 maps for the neighbors , therfore , avoid static mapping which causes this problem.
Mohamed Sobair
