Error uninstalling Cisco VPN
Aug 21st, 2007
I am trying to unistall my current installation of the Cisco VPN Client so i can install a newer version but everytime i try i get the following error:
Error 28000: Before installing the Cisco Systems VPN Client 5.0.01.0530. you must uninstall the previous version of Cisco Systems VPN Client, using the Add/Remove Program Files option in the Control Panel. Then restart your system.
This is in Windows Vista Business
Anyone have any ideas how to resolve this?
Renevanhezewijk Thu, 08/23/2007 - 14:08
Why not use the VPN clients own uninstaller? (Via START/Programs/Cisco/uninstall).
However: uninstalling appears to ignore the "old" user data: I uninstalled several times as well by diverse methods, but the new version still new who I was and what I wanted. Not a very clean uninstall, that is. Perhaps a registry cleaner will help, running it after uninstalling?
