Regarding GBIC modules on SUP V of 4507R
Aug 21st, 2007
  • Silver, 250 points or more
Hi experts ,
We have SUP V modules for 4507R switces and we want to use GBIC present on SUP V for connecting two 4507R switches back to back.
What type of cable we can use to connect these ports of SUP V.
when i checked it is showing uplink 1 and uplink 2 and it had 20 pin female connector inside.
satish
royalblues Wed, 08/22/2007 - 01:25
  • Green, 3000 points or more
Satish,
The Uplink ports for 4500 with SupV requires GBIC modules mostly WS-G5484
To connect these you would require SC-SC cable type
HTH, rate if it does
Narayan
