CSRadius service will not start
Aug 22nd, 2007
ACS 4.0 and Windows 2003 server.
The CSRadius service will not start automaticly, and after a reboot we have to start the service manually.
The evenlogs says this:
EventID:7000 Source: Service Control Manager.
The Open Procedure for service "CSRadius" in DLL "C:\Program Files\CiscoSecure ACS v4.0\bin\rad_mon.dll" failed. Performance data for this service will not be available. The Status code returned is the first DWORD in the attached data.
And then this one:
"The CSRadius service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion. "
Any suggestions ?
JF
rochopra Wed, 08/22/2007 - 04:12
  • Cisco Employee,
Make sure that you are not using multiprocessor/hyperthreading on the machine.
Also you do no have SP2 R2 of win 2003 installed, these are not supported environment.
Also remove the logs from following folder
/CSRadius/Logs.
Then restart the service
~Rohit
p.karsanidis Thu, 01/19/2017 - 01:53
Our Cisco ACS on Windows 2003 server has been online for more than 9 years (!), but we recently decided to convert it to virtual, so we noticed this problem/bug: CSRadius and CSTacacs services failed to start automatically after reboot.
My solution does not require anything from TAC. I just told Windows not to start these services immediately when it boots but start them a few minutes later. In detail:
  • From services.msc I changed these services from "Automatic" to "Manual"
  • Created a bat file with the following commands (in bold):
timeout /t 300      ===> Waits for 300 seconds - it is crucial, otherwise you may still have the same problem
net start CSRadius
timeout /t 10      ===> Waits for 10 seconds - may not be necessary, but just to be safe
net start CSTacacs
  • Created a scheduled job that runs the bat file every time the server starts
I hope this helps any other "old-timers" like me run into the same problem :)
Premdeep Banga Wed, 08/22/2007 - 04:17
  • Gold, 750 points or more
Please read details about this bug,
If services start successfully manually, but not automatically.
CSCsb81671 : CSTacacs and CSRadius services fail to start with Windows 2003
Workaround is to get a file from TAC, and apply it on ACS.
Prem
