08-22-2007 01:33 AM - edited 03-11-2019 04:00 AM
If a new packet(192.168.10.10 source ip from inside to outside) comes into a FWSM, which public ip address will be translated ?
FWSM(config)# static (inside,outside) 209.165.200.226 192.168.10.10 netmask 255.255.255.255
FWSM(config)# static (inside,outside) 209.165.200.232 192.168.10.0 netmask 255.255.255.248
Please tell me how will be working and a reason why
08-22-2007 04:23 AM
Unless there is an existing xlate for that address, 192.168.10.10 should be translated to 209.165.200.226 because the order of operation between statics is first match wins.
Could you enter the commands without an error?
08-22-2007 08:23 PM
there was no error when i enter the commands.
is the order of operation matching first in a whole nat-static configuration? not loggest match ?
08-22-2007 09:35 PM
Why dont u verify the xlate .
Please issue the following command to check out
sh xl loc 192.168.10.10
In case there is already an existing translation for that we can use the following to clear the xlate table cl xl loc 192.168.10.10
and recheck it again
Raj
