frame relay connections
Aug 22nd, 2007
Hi all, can anyone tell me if you can have frame relay over a serial connection, and also are they normally over e1 connections? also whay speed can frame relay go up to?
graemeporter Wed, 08/22/2007 - 03:01
Hi there!
Yes, Frame Relay works over serial connections.
We have a number of sites in the UK which are connected together via MPLS. Each of the sites links to the MPLS cloud via a 2 MB Frame Relay connection. We connect the routers to the NTE via a serial cable and serial WIC.
I'm not convinced E1 is the normal medium for frame relay.
Not sure about maximum frame relay speed; sorry.
Kind regards,
