08-22-2007 04:31 AM - edited 03-09-2019 06:39 PM
For a site with 300 users is the CS-MARS 20R sufficient or do we need to scale up to 110R?
08-22-2007 06:17 AM
i think it depends upon the eps your cs-mars is getting. try to find the eps rate which your mars-box is getting from your logging devices then according to that you can plan for the right box.
08-25-2007 03:33 AM
I agree with Diptanshu regarding trying to figure out your EPS (Events Per Second) rate first then sizing your box.
Then remember this guideline:
Size the box to be capable of handling 3 times the low end of your EPS (Events Per Second) and also to be capable of handling 6 times your estimated high side EPS.
Here are the guidelines for Generation 1 Boxes:
1. MARS 20
(EPS) = 500 Events Per Second
Netflow = 15,000 Events Per Second
Storage = 120gig (No RAID)
2. MARS 50
(EPS)= 1,000 Events Per Second
Netflow = 25,000 Events Per Second
Storage = 240gig
3. MARS 100e
(EPS) = 3,000 Events Per Second
Netflow = 75,000 Events Per Second
Storage = 750gig
4. MARS 100
(EPS) = 5,000 Events Per Second
Netflow = 150,000 Events Per Second
Storage = 750gig
5. MARS 200
(EPS) = 10,000 Events Per Second
Netflow = 300,000 Events Per Second
Storage = 1,000gig
I haven't worked much with the 2nd Generation of MARS boxes but here are some of the claims:
Next Generation MARS Appliances:
All the new MARS G2 appliances are 2U in form factor, have dual-PSU and have fewer disk drives, which offers an increase in overall reliability.
They will deliver up to 2x the storage and 1.5x the performance of the old generation 1 appliances.
These new appliances will run the v5 track of software, which offers many new enhancements.
New Gen2 Software Enhancements:
A new Enhanced pnrestore options to restore data in time slices.
New Support for raw messages greater than 500 bytes.
A New keyword search process.
Super New IP log enhancements for viewing IPS IP packets.
A licensing upgrade will be available for customers on 110R to upgrade to the 110 platform.
Hope this helps.
