7961/41-Clear network settings
wrkemmer
Something simple that I haven't been able to figure out.
On the 7960/40 phone models, I used to be able to get into network settings, scroll down to option 33 and hit **# to allow me to erase the network settings. This would clear everything and grab the settings again from DHCP. How do I do this on a 7961/41? The "erase config" option is not available under network settings anymore. These phones haven't been restricted in any way that I know of, unless there is a default to do this.
mchandak
Level 7
Level 7
Please try the following:
1) Hit the Settings button
2) Enter **#
3) When the screen says Unlocked, hit the More softkey
4) You should then see the Erase softkey.
mchandak
Level 7
Level 7
2) Enter **#
Thank you. That did it.
